- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Wait, are you saying have the pumpkin twist upside down, then turn it around? To put it under the springs?
Also, do you think maybe just drop shackles and maybe taking a single or 2 leaves out would suffice for drop, anything else accomplishable by smaller tire?
No. Put the axle on top of the springs, upside down. Will drop you 6 or 7 inches. The reason upside down, you do not have to weld on new spring pads. If you change the shackles, you will only get 1/2 of the added length.
What I posted, is how you can accomplish what your question was in the very first post. "Can I just put the spring under the axle?"
