MikeB
- Apr 4, 2014
- North Texas
- Mike
- C10
Here's what I've used on a few vehicles, including my 82 C10 with all new front end parts:
https://www.summitracing.com/parts/sps-91000/overview/
You really have to understand the concept of caster and camber, and how adjusting one affects the other. And if your garage floor is sloped front-to-rear or side-to-side you'll have to factor that into the gauge readings. Also, if the truck is a lot lower in the front than the rear, you may not be able to set caster to spec.
By the way, I didn't read all the responses above, but inside tire wear could also point to ball joints and/or loose wheel bearings.
