C20 vs c10 spindles
kzguns
northeast ohio
Ken
suburban 20
Can anyone confirm that I can get c10 spindles for my 85 c20 and just ream the ball joint holes for the bigger ball joint and still run my 8 lug hubs. I read this somewhere and not sure
ali_c20
Austria
Alexander
C20, K5
Hi. No you can't cause the C20 spindle has a thicker shaft and needs bigger wheel bearings as the C10 one.
kzguns
northeast ohio
Ken
suburban 20
Thanks. That’s what I thought.
kzguns
northeast ohio
Ken
suburban 20
Thanks! I ended up ordering from switch so I should be good to go
Long Rider
La Grande Oregon
Has anyone put C10 front coils in a C 20? I am looking to lightly lower the front of my C 20, 2 inches, and already have a set of new C10 springs.
ali_c20
Austria
Alexander
C20, K5
C10 and C20 use the same coil springs. Compare the part numbers at Rock Auto or check application at Summit.
https://www.summitracing.com/parts/mog-6454/applications/make/chevrolet
There are many after market lowering springs out there. Best would be lowering spindles, they don't change the geometry of your suspension and steering. Just drop them on and you're good to go.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
We just used a torch to lower in the ol' days, probably not kosher now days...
idahovette
Weiser Idaho
Perry
K20-K10
^^^^^YEP watched my Dad torch my 15 year old Brothers 51 fored 2 dr and set it in the WEEDS!!!!!!^^^^^^^this was out on the farm 8 miles from town.....couldn't wait to go take it to town!!!!!!
84K30dually
