C10 lift options?
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
So would 80 be higher that 75?
SlickGTP
Houston, TX
If you're talking about tires then yes, but not by much...
Conventional tire designation like ***-xxRxx describes the dimensions of the tire.
The first number is the width of the tread in millimeters.
The second number is the sidewall height as a percentage of the tread width.
And the third is the wheel diameter.
So, a 225-45R19 would have tread 225 mm wide, sidewall height of 101.25mm(45% of 225mm), and wheel size of 19 inches.
The difference between a 75 and 80 on sidewall height will be minimal and dependent on the width of the tread.
Another consideration when changing tire sizes is that your speedometer will need to be corrected as well.
Iowan
Iowa
Calvin
K1500
350 crate
Thanks
highdesertrange
kalifornia
mike
k30
never do a suspension lift on an independent suspension vehicle, unless you have really deep pockets. highdesertranger
Iowan
Iowa
Calvin
K1500
350 crate
Ok. I dont have those.
SlickGTP
Houston, TX
The front suspension on our non 4x4 trucks are independent...
Georgeb
Wisconsin
George
K10 Burb Z71
I think he meant he doesn't have deep pockets.
Iowan
Iowa
Calvin
K1500
350 crate
yeah I did mean deep pockets. should have specifed
thatgermanguy
