- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I know you're kidding but a burb tag on a K5 would be WAY too easy to snuff out
Without doubt, you ever do something of that nature, it had better Burb to Burb and the same body style at least. You don't go putting a long bed VIN and a short bed either. Or a single cab on a crew cab etc. They better be a pretty close match. Actually best to avoid it. In OK, you can do things like this, BUT, you have to take the vehicle down for inspection, they reassign a new VIN. This is usually done if say, someone replaces a damaged cab on a truck, and the donor truck cab is from a wrecking yard. A ndw VIN gets assigned and its riveted inside the driver door post.
