DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Are these new pistons? Did you install top ring with the bevel up and secondcring with the bevel down.A trick for working outside in the cold throw a tarp over the car and put a forced air kerosene heater behind the car blowing under, you will be in a constant warm draft. I changed a 2 piece rear seal in 10 below weather this way.
Because heat goes to cold
