Burb is no-go - fuel pump or filter??
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Leaving our neighborhood this morning going up a steep hill and lost power, engine still ran (barely) for a few seconds but then died. I was able to start it a couple three times - enough to get turned around - but then had to coast all the way back to my house. (Luck was on my side there). Now it won't run at all and no change in sound when cranking like it's trying to start. Also, the tach went really wonky - bouncing all over the place - after lost power but engine still ran.
Tach makes it sound electrical? The reason I say fuel in my title is I have a pressure gauge installed at the TB and it only reads 6 psi when key is on - too low to fire injectors? Also don't see any fuel spraying when someone else cranked for me. I do hear the pump when I turn key on. I also checked for codes - just flashes "12" over and over again so nothing there.
I'm going to start by replacing fuel filter and then fuel pump (I have a walbro 190 already for my 383 build) unless I hear differently. Any further diagnosis I should do? Why would a fuel problem make the tach go wonky?
TRAZOII
Phoenix
Anthony
K10 Sub
Pull a plug and check for fire before you do anything. Tach went wonky sounds like ignition
Sent from my SM-G930V using Tapatalk
rumblebox
Victoria, TX
Carlton
You need like 60psi
Sent from my LG-H910 using Tapatalk
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
You need like 60psi
No... TB only requires 9-12psi. But preferably 13psi in my experience
rumblebox
Victoria, TX
Carlton
Weird
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
I agree with Traz also, being ignition related. Maybe wiring to the coil. Common failures there. The gray & black connector duo
The fact you only have 6psi is weird too though
rumblebox
Victoria, TX
Carlton
Yep. Didn't know TBI could function with low pressure like a carburetor
TRAZOII
Phoenix
Anthony
K10 Sub
Carbs run right around 6-8 psi
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
lol that's funny 9-13psi I got used to 1100+ psi.and running lean below 950psi.
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Ah yes! I getya... I'm thinking GM due to the forum...smh
You're always bringin the VW garbage in here...
***ducking*** lol
dljohnson55
