crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
Do I sense lifted truck envy in that post???
Keep an eye on craigslist for someone selling a 6" lift kit, I see them on my local CL all the time. If you can get the front lift springs you can use a shackle flip kit out back for 4" of cheap easy lift, then add a 2" block which doesn't have near as much axle wrap as a 4 or 6" block. Then you just gotta get shocks, which on the low end are around $40 a piece.
i don't recommend the 52" spring conversion up front...then your dealing with castor angle issues that take some knowledge to get right.
Cheap.....either find something on cl or go rough country lift. I don't care for blocks but its cheap. For rear suspension, i prefer the shackle flip route with slightly longer shackles (about 5 1/2") and a zero rate/ez-inch.
Keep in mind with a six inch lift you will need new shocks (previously mentioned) and extended brake lines. 4", you can get away with modifying the brake line brackets.
If you want to go more flex in the rear, find some one ton 56" springs and shackle flip it. I have 56" rears and love 'em!
Just my $.02.
oh yea most definately.
I wonder though I've only heard maybe one guy talk about add a leafs up front. You can do that right? no issues?
Then 2nd question would be can you do an add a leaf(spring) and then put on the zero rate block?
just doesn't make sense to me when i see 6in blocks on the rear of a truck. It just looks like i can walk over give it a shove and push it sideways off it's axle, and at the distance the u bolts are under more stress. i know it works, but i don't like it. And not only that, it looks like **** to me.
If he comes back, I think there is a member on here removing a lift kit off a truck he recently bought. Remember he was looking for stock springs??? He might make you a deal and ship.
lots of different ideas. my plan was to swap the 3/4 tons in and do a rear shackle flip with 2" lift 56s in the rear with some 6" lift front springs. my only concern is how hard it will be to piece the lift together vs. buying a complete one.
