- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
One more thing..... Do I need to run anything from the Manifold Vacuum Port?
If the brake booster gets vacuum from the base of the carb. and not the vacuum port on the manifold, that is good. Do you have an automatic transmission? That needs two vacuum sources.
I don't see air conditioning, that also would need vacuum.
The charcoal canister needs vacuum but the truck may have that removed or disconnected.
