87V30
- Jul 24, 2018
- USA
- Kevin
- V30
Hello,
I have been rebuilding my 87 V30 for several years and recently got it moving under its own power. I am posting as have run into a brake system issue I discovered because of the combination valve/ proportioning valve warning light coming on and immediately coming off at different stages of pedal engagement.
My truck has a remanufactured hydroboost brake booster, remanufactured master cylinder, new stainless steel hard lines, new rubber hoses, fresh calipers, rebuilt drums and new pads/shoes.
I have been moving the truck in an out of the garage and in the driveway for several weeks without issue and a nice pedal feel. This past week I installed the instrument cluster/dashboard and had the warning light illuminate and go off at different points in the pedal throw.
I verified the park brake and metering valve warning switch circuits are correct and not shorted to ground. Further, I was able to have a friend depress the brake pedal while I looked into the metering valve switch port and saw the valve slide to the driver side which tells me there is an issue somewhere with the front braking system.
I reset the proportioning valve to center and used a plastic thread-in tool to bleed the front brake system in hopes of finding a leak point. There was a significant amount of air in the system that just kept coming. I am under the impression there is a leak somewhere in the circuit but I see no puddles or drips at fitting points or changes in master cylinder reservoir fluid levels. I have verified all the fittings are tight and have been watching for leaks. My pedal has remained firm this whole time and is within the specified 3.5” of travel. The rear drums/adjusters have been rechecked and adjusted per the GM light duty truck service manual. On install I did a thorough bench bleed of the master cylinder too.
Am I overlooking something? Is it possible for air to enter the system without an obvious fluid leak or for a failing master cylinder seal to introduce air into only half of the system? Any input is appreciated. Thanks.
I am attempting to attach an image showing the valve movement in this case.
