-put yellow teflon tape on all of the flare fittings and confirmed they are tight, not cross threaded and not leaking.
-replaced both rubber return lines. That is the PS pump to Hydroboost and PS pump lines. I already replace both pressure hoses.
-replaced all of the hose clamps in the system and ensured they were tight
-bled the air in the normal, wheels elevated, lock to lock multiple times fashion
-used a vacuum pump at 15mmHg which held vacuum confirming that there are no leaks
-turned the wheels lock to lock 10 additional times without seeing a single bubble
Pedal returns much more frequently, steering and braking have are quieter but the pedal still hangs occasionally. It most frequently occurred when I applied slight pressure when slowing. From a stop, I found that the pedal resets once I’ve begun to accelerate.
Going to continue trying to bleed more air from the system with the vacuum pump. Also going to spend the 5 or so bucks to replace the pedal return spring.
Earlier in this thread,
@AKguy mentioned that hydroboost units possibly had different rods of different lengths... the one I installed is 71217. Like an idiot, I didn’t measure or note the stamping on the rod that came off the truck before I tossed it.
Does anyone know the other stamping number and/or length? Truth be told, I don’t even know the length of the rod on the unit installed in my truck.
@Rusty Nail, I added pic for you!
-Eric
