shiftpro
- Aug 31, 2012
- BC Canada
- shiftpro
- 1500, 2500, 3500
- 350, 383, 454, 496!
Thanks Derek. Ok so a semi-floater is just your average differential then, like a 10/12 bolt. I thought it was something between this and a full floater.What makes it "semi-floating" is that the outer bearings ride on the axle shaft. Only yhe inner half of the axle is unloaded. In a full-floating rear the bearings are contained in the outer hub and the axle bolts in, carrying no weight.
