Green79Scottsdale
- Aug 8, 2010
- G.R. - MI
- Bob
- K20
So, got in the truck to move it out of the garage the other day. Push the brake pedal and it stops in the usual manner, for a few seconds anyway. It proceeds to slowly go to the floor. Damn. Get out to look for leaks, nothing, front or back. Damn. Master cylinder must be bad.
My first question is, after you put a new master cylinder on (after bench bleeding of course), do you need to proceed to bleed the entire system? Conventional wisdom tells me yes, but I have heard of bleeding it at the fittings on the master cylinder. Anybody have experience doing this? Can I get away with just bleeding the fronts after a master cylinder replacement?
I ask because during my search for a leak I noticed the condition of my rear brakes (14FF) is something to be desired. Around the bleeder screws is all rust, and I am pretty sure if I touch them, they are going to break off. If that happens I will be forced to pull the axles to fix it, which is going to lead me to do a disk brake conversion. I do not want to do all this at this time as I have other things that require my time and money.
What says the GMSB community?
