Bilstein 4600 Front Quad Shocks and Dual set rear 90 Suburban
Rashad Baker
The Dirty South
Rashad
V1500 Suburban
Can anyone tell me what part number is used for the Bilstein 4600 quad shocks up front and dual set for the rear on the 90 v1500 Burb?
Is the front Bilstein 24-009232 and rear Bilstein 24-009331?
Raider L
Shreveport, LA
William
@Rashad Baker,
The number I have for the 4600 is 24-192941 heavy duty shock. But there might be some different number or two for a Suburban. Let me look it up. You number is right from the site. The number I gave you is for '74 -91 C-series, Blazer, and R10-R30 '87-91. May these might work as good or better since they are for trucks and off road, crew cabs, etc.
mcarlo86
ND
Suburban
So we are looking to replace the front shocks on our 90 V1500 suburban. From what I have been seeing on other threads, we should be just fine with just single front shocks on each side? Just want to double-check, I'd like to go with Bilstein 4600's and I believe the part number we need would be the 24-009232's like the OP posted above. Should be for the outside shock location and then we would just ditch the inside shocks?
F1r3truck
