big block heads question
puke171
Kansas
Wes
427 Tall Deck
I have a set of 772 heads off an 83 427 tall deck and im wondering if I should have them rebuilt and the bigger valves in them, or spend the extra money on 781 heads?
68post
Indianapolis
Tim
454, TBD
It really depends on your goals. Will this be a work truck , drags only, or something in between ? How big of an engine will these be on ? Auto trans, heavy truck ?
hirschdalechevy
norcal
rich
k-30
In my opinion if you are doing a low dollar build I always use the early model semi closed chamber big oval port heads , brings the compression up and they and they are torque monsters , and you can port and put bigger valves in them if you want , work very well in a truck , (ls-5 and l-35 , 290 , 063 , 280 , 290). They are not the best flowing but compression is power and they are good for a pretty stockish 454 and will punch out 450 hp with little effort.
puke171
Kansas
Wes
427 Tall Deck
The heads are going back on the 427 tall deck. That I am going to put in a 79 K25 with the sm465, np205, with 4.10 gears. And the truck is just a work truck nothing else. I'm going to use it to cut fire wood and pull a gooseneck. So the horsepower would be nice but I mainly what the torque.
jlyon1006
