Best way to quiet an exhaust
84 Shorty
Grovetown, GA
Andrew
Yes that’s right, I want to quiet my my exhaust on my truck. It’s a little obnoxious paired with 4.10 gears, th350 tranny and camed sb. Looking for the best and cheapest route to go to quiet my Flowmasters down. The exhaust turns out to a 90 behind rear tires.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
Replace your flowmasters and make sure the exhaust doesnt exit under the bed at all.
84 Shorty
Grovetown, GA
Andrew
It exits outside the bed behind the tire. What about resonators or silencers? Replacing the whole system won’t be cheap
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Id just replace the mufflers only. Go with a Dynomax or Magnaflow muffler.
I dont weld, but Im sure a shop wouldnt charge much to cut off mufflers and weld in new ones, especially if it were a cash deal.
2 mufflers might cost you 100-150 depending on how long you get. The longer the muffler, the quieter it will be. And you dont loose power doing that.
84 Shorty
Grovetown, GA
Andrew
Thanks for recommending dynomax. I listened to a sound clip of the super turbos, I was inpressed.
78C10BigTen
pennsylvannia
C10 BIG TEN
I like that setup. Looks alot like mine except mine turn at a 45 b4 the rear and stay under the bed
4WDKC
Southern Florida
Kacy
you can add an x pipe it helps take some of the sound out, down side will be it will sounds like it has a smaller cam in it.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I got annoyed with my thrush welded mufflers (similar to flowmasters). Read good things about magnaflow and had a shop change mufflers to them.
At first I was disappointed- it was so quiet it idle I didn't like it. But it just was from the "shock" of something so different. I like it a lot now. Quiet at idle, pretty quiet on the highway, but will sound mean when you floor it.
My exhaust just dumps under the bed near the front axle BTW.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Thanks for recommending dynomax. I listened to a sound clip of the super turbos, I was impressed.
That's what I have. I went to the muffler shop thinking Flowmaster but the guy said I wouldn't be happy with the extra noise since I drive a Suburban. That was 16 years ago and if it ever wears out I'll put the exact same thing on again.
yevgenievich
Place
Name
Year
Model
Size
Big body rv mufflers and exit out the back instead of the side.
climb-101
montana
seth
c2 crew cab
6.0 LS
magnaflow i had on one truck wasn’t bad. the best one i have had and still have is my corsa setup. not loud just cruising, a little rumble when you really get in it and no drone at all. the magnaflow has a little drone right at cruising rpm
yevgenievich
Place
Name
Year
Model
Size
when I had turbo mufflers on my TA they were nice with little to no drone and opened up at higher throttle
So are you wanting to hear your girlfriend better or hear the stereo???
Find some of those OEM round stock mufflers off a 3/4 ton big block. They're quiet as can be. All I even hear of my engine is carb roar when I nail the skinny pedal.
78C10BigTen
pennsylvannia
C10 BIG TEN
Thats why i like my flowmasters half under the cab and half under the box, open the slider and nail the skinny pedal and i love the roar!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Wargasser
