Bent
Carlton Huitt
Gilbert Az
Carl
C 10
Push rods. This was a 73 350. That was running good with bubblegum and spitwads holding it togoether. I was in the process of replacing valve umbrella covers. I found intake valve pushrod 2 and inyake 8 bent. Does that means death inside that bitch and I need to pull her? Or patch her up and see? I dont know..........
kidego31
Tim
c10 silverado
I would pull the heads for sure and see what is going on. You got stuff bent there is something that is probably not good. Might have been over rev'ed at one point and floated a couple of valves.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I'd just pull the intake and inspect the lifters, pull them and make sure they haven't collapsed or taken out any cam lobes, and put them exactly back where they came from. Check the other pushrods too, of course. There shouldn't be anything wrong with the heads, id say pull the intake at the minimum and inspect lifters and pushrods and replace the bad pushrods.
If everything checks out I would run it. The valves shouldn't have contacted the pistons, depending on the motor setup of course.
I do agree that pushrods bending is usually over revving. Can also be from wear and tear, manufacturing defect, etc.
ben_swager
