Bent Crossmember
How about a big bench vise??? I"ve straightened some flages to one with a bench vise before.
79K10
Sacramento,ca
Ryan
350/th350
ok so i got it bolted back up. ended up bolting the crossmember to the adapter plate first, I put in two bolts loose on one side, oh i moved the spacers to the bottom of the rail, figured id make it easier on myself, i have a 4'' lift block and front spring to go on, and it made it way easier to start the nuts, then i used air ratchet to buzz it all tight. worked out.
now onto the transfer case...
Cool !!! I had to do mine a bit different too since I had some bent issues on the frame rails from the bent crossmember. Pretty much sucked, but I did get it in and it's working fine.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
necro posting here....
HRPC, how did you fix the frame? my crossmember is straight, but the frame is bent like in your pic on the drivers side
I never did get it perfect but got it pretty damn close. Had a piece of 3.5 or 4 in heavy guage channel iron that I drilled a hole into. Then used a hardened bolt, and air tools and tightened the hell out the channel iron with the bolt to the frame and is sucked the frame to match the channel iron edge and flatten it out.
flyboy1100
UsA
me
k1500
i might have to try that!
does it really matter though if the crossmember is angled forward?
No, not really. The flexible trans/crossmember mount absords some of that angle.
flyboy1100
UsA
me
k1500
well, whenever i pull my TC to either rebuild or replace i will try to straighten it out
TDW1
