Bent Crossmember
This crossmember drop trick is also good to know if anybody puts a 2wd cab on a 4wd frame to help with floor clearance issues. :High 5:
That I was aware of. I was thinking of doing a 2wd Cab on my 85K10, but doing a 2inch body lift instead of using the 4wd hump. That would sure make for a long reach to shift the Tcase though. Although, probably not so bad. Not like you are constantly shifting it.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Make an extension.
79K10
Sacramento,ca
Ryan
350/th350
I know this thread is a bit old but I have a quick question for you guys, I have a slightly bent crossmember from my front drive shaft braking loose from the yoke and smashing my tranny, fuel lines and the CM,,, is there a way to straighten it out? say i put some weight on it, like a small car to bend it back?? or drill the holes a bit bigger on the CM, its only bent a tiny bit. Or do I just need to go to the pick and pull and find one?... thanks for any help
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
A torch and a BFH might be able to adjust it if a little is all it needs. Often times pulling a car onto something to slightly adjust something usually adjusts a little too far.
79K10
Sacramento,ca
Ryan
350/th350
youre probably right about the car being too much...lol... what if I just drill the holes on the crossmember bigger so I can get it bolted up? im I wasting my time? should i just go to the pick and pull and look for one? this truck is starting to be a bigger hassle than its worth! thanks
crazy4offroad
Curt
K-10
350/SM465/NP205
As long as the trans mount doesn't get bound up by moving it. Can you just use a spud to align one of the holes so you can get a bolt in the other?
79K10
Sacramento,ca
Ryan
350/th350
whats a spud? I can get two bolts in on one side but the other is about 1/8" off... thats why i thought about drilling the crossmember bolt hole larger...
thanks
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Put the two in you can and leave them loose. The spud tool is a pointed spike basically to pry to crossmember into position where you can put a third bolt in and the pull the tool out and put the fouth bolt in and tighted them all down after that. Mine was bent towards th back some and i hooked my winch cable off my rollback to it and wedged the back tires againts the bed and pulled slight pressure on it towards the front and got it pretty close only to bend it back again about a week later playing in some rock piles out behind the shop.
79K10
Sacramento,ca
Ryan
350/th350
oh ok, force it in! lol ... sounds good to me, ill give it a shot in the morning.
thanks for the help!
crazy4offroad
Curt
K-10
350/SM465/NP205
The local Tractor Supply has these spud wrenches in their bargain bin as of earlier this past week...
attachment.php
TDW1
