Bent clutch pedal?
Jalopy
manteca california
joe
383 stroker
The clutch pedal hits the high beam switch is there an easy fix?
dvdswan
Port Orchard, WA
Dave
How far away is the pedal from the "A" pillar? Normally, it is like 2".
I would check those pivots and the pivot.. part.. is the pedal wobbly side to side? I just went and pushed my clutch, I have an inch if not 1 1/8 or so between the clutch pedal and the switch and then the pedal pushes a fair amount past the switch as well. your floor is intact?
I've got a good amount of clearance too. I'm wondering if the high beam switch is screwed down in the wrong spot.
Could the pad scoot over on the pedal? I dont know what the back looks like, but if the rubber is worn and someone pushes at a left angle or kind of swipes off the pedal rather than pull off over the years maybe its scooted.
Otherwise maybe someone had a binding z bar thing and pushed a little hard or over the years someone had some insanely strong springs they were exercising the ol leg on lol
IF anything my pedal looks a little kinked.. lol... but so does my floor. and everything. lol
unimogguy
