bearings instead of bushings front control arms
scubacarib
bastrop tx
john
c15
i have 76 c10 with rubber bushings can i convert to bearings instead of bushings ?
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
Look into delrin bushings. I think some race cars use this stuff. It's super stiff engineered plastic, should be able to get custom sizing from some supplier that would fit as bushings. Or you could try to weld and engineer tubular control arms with heim joints, another race car-y thing
Catbox
Peter
C20 Silverado Camper Special
I would look into polyurethane bushings.
They made a big difference on my '73 VW.
F-64
nyc
mike
R10 lwb
5.7 tbi stock
Just like Nabeshin said...look into Delrin. Detroit Speed and Engineering and Mark Stielow use Delrin in their lower control arms.
Here's Mark
https://www.hotrod.com/articles/mark-stielow-built-12-camaros-so-you-dont-have-to/
DSE
https://www.detroitspeed.com/front-...ird-1968-74-nova-dropped-spring-pocket-031201
steel bushings
https://pitstopusa.com/c-135890-sus...arms-control-arm-bushings-steel-bushings.html
There may be a way of using needle bearings as the swing arm on my motorcycle uses them in the pivot.
WFO
Texas Panhandle
Since bearings don't have any give in them, I'd think they would hammer open the holes in the control arms when hittin pot holes and such.
Just replacing worn out bushings with new ones makes a big difference.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
contact Global West, they make numerous Delrin bushing sets for GM and Ford. You may need measure your control arms so they can possibly match on the shelf parts. I installed a set on my 94 Vette up front. No increase in ride harshness as I didn't change either the shocks or spring rate. The lack of flex/give from the factory rubber made the steering and suspension response much sharper.
Donald
Loris SC.
Don
GMC 1500
Blue ox is right , you will get a lot more road feel in your steering .
MikeB
North Texas
I'm not sure how you'd engineer a modification to accept some type of bearings.??? Neither the control arms or shafts are machined for bearings/races. It would take lots of machining and possibly welding and fabrication. And for what benefit?
I highly recommend name brand poly bushings, like Prothane or Energy Suspension. Much easier to install than rubber bushings, and they will never crack. Be sure to use liberal amounts of the proper grease. Some say the ride is rougher than rubber bushings, but I've never noticed it. I've also used them in cars with no noticeable difference, except for quicker steering response. It's a win/win deal.
https://www.summitracing.com/parts/ens-3-3161g
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
What was your thought process about going from bushings to bearings?
I can’t picture a scenario in my head where bearings are better than bushings.
F-64
nyc
mike
R10 lwb
5.7 tbi stock
Arkansas, bearings will prevent any bind allowing the suspension move freely along it's axis. At the same time it will keep the suspension alignment settings from straying outside of that axis. This will help with keeping your contact patch as consistent as possible. I'm not sure if that is why Scuba is looking at bearing though. You could also run heim joints.
scubacarib
bastrop tx
john
c15
sorry for the loong delay i had some older chevys that used bearings they were the heavy duty 8 lug trucks
Auburn, Washington
Define "older".
And why would this be a consideration?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
The old C20 bushings were steel, no deformed holes in the arms.
texczech
