BBC 454 dipstick length?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Ok I changed the oil in the square today.
Look at them tires shining still after 3 weeks and a couple rains. Lol
Anyways, I put 7 quarts in and it bearly touches the dipstick.
So question is how long is your 454 dipstick?
This one is one of the aftermarket chrome jobbers and I think it might be short.
Still has good oil pressure at idle
Maybe I'm good. I don't know.
carfanatic63
Houston
Austin
C15 SWB
Mine did the same thing. I just put 7 quarts and did a pipe cutter on the tube to get it reading correct
82sbshortbed
Fuckemall!!
SE Texas
Doug
Not a bad idea. Thanks from a fellow Texan about 25 miles south of ya.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I can't believe my eyes.....a Fram oil filter?? I cannot unsee that which I have seen!!! LOL I'll just chalk it up to the glare off those tires! Lookin' good!!!:cheers:
:lol: :favorites13:
Customblue
Locust Grove, Va
Brandon
Do you have a stock oil pan or aftermarket? Stock *should be five quarts, not including whatever your filter takes holds.
QBuff02
Central IL
Quincy
I run a Moroso Deep sump pan with their matching dipstick- 7qts in the pan and one in the filter is pretty much dead nuts to the full mark on the dipstick.
QBuff02
Central IL
Quincy
Wix or Napa, which coincidentally are the same filters. I run a Napa 1061 on my 454, it's the one we put on in the engine shop from the parts room and it's the only one i'll run. If my Engine guy is putting them on his rebuilds, it's because he's done the research so it's good enough of an answer for me!
82sbshortbed
Fuckemall!!
SE Texas
Doug
I just don't want to over fill it and cause problems. How do I tell what oil pan I have?
Shorty81
Baby Boomer
North West ohio
Darren
. Doug, I have a Moroso 7qt pan and here is my dip stick.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Ok we're at about the same mark on tape.
Do you put in 8 quarts to get to the full Mark?
Thats about what my 99 oldsmobile aurora takes in the 4.0 northstar V8 in it
Mikesrinc
