Thank you sir, you are too kind. What else can I say? Everyone gets lucky once in a while! That leaves the bar awfully high - don't ya think?
Moment of weakness?
LoL...
I believe that these old trucks are good for a great many things and this MSB has found a collection of some pretty awesome folks my dude, it has nothing to do with me - I just work here!
*edit*
When I was talking to Gary Camaro about an LT1 camshaft he suggested that I stick with a '93 or '94. Some jazz about how the OPTI-SPARK changed for the 1995 model year and there was some type of change on the camshaft too. Maybe a drive apparatus of some sort? Whatever it is, I agree with him.
There is no need to have unused rotating mass on the end of a camshaft.
The cam timing changed between 93 and 94, I believe ending to be more
refined for 1994 and that is my choice. I will gamble that a 1994 LT1 camshaft will be THE hot ticket for my K5. I'll do it last and that will throw me over the fuel pump edge..
Specs on Stock TBI cam @ .050″ is 165/175 and lift with 1.5 rockers is .382/.402.
I think that camshaft, the Corvette #113 heads, Holley 701r-48 intake, the headers and exhaust, plus THIS throttle body deal I want, will exceed the abilities of my brand new, AC DELCO, stock replacement, fuel pump and I aim to find out. Wouldn't that be somethin? The 58cc heads will bring my CR much closer to 1994 LT1 levels with no other changes. Everybody knows I support the "305 heads on a 350" swap and this build will be no different because it works.Good, when done correctly. I believe the use of aluminum heads over iron will eradicate the necessity for 91 octane PLUS i'll be able to tune it into the chip.
I consider dude's LS1 electric fans swap, great idea!
Isn't that enough?
https://www.ebay.com/itm/GM-TBI-por...-14cd-4178-b2aa-adf5f844b1da&epid=10023322039
I'm finished. That is my TBI build plan, laid out before yous all.
For FREE.
With as many USED , OEM, STOCK parts as is possible.
Stock short block -made into a roller motor-,
WITH the chip!
It's gonna kick YOUR truck's ass!
Lolololololol!
Thanks to the OP for starting this thread.
