meyer
- Jun 10, 2017
- arizona
- Ben
- C20
1977 C20 350
I recently bought this truck and its back brakes lock before the fronts. Not only this, but they lock pretty easy.
I have replaced the following with still no luck.
rear drum brake cylinders
rear drum brake spring
rear drum brake pads
rear drum brake drum
rear flexible hosing
front calipers
front brake pads
front disks
front flexible brake lines
proportioning valve
master brake cylinder.
With my luck of course its going to probably be an easy $5 fix
I need help as this is unsafe to drive.
Ideas? Thank you
front calipers
front brake pads
front disks
proportioning valve
Ideas? Thank you
