aztec cooling fans in a 86 square
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
well I made a mounting adaptor to mount a Aztec hd cooling fans and shroud on my heavy duty diesel radiator made out of 18gauge sheet metal cut the top and bottom to 32in and bent to L brackets on the picnic table with a 2x4 clamped to it then cut the sides to 15 in and bent to L brackets mounted the fans to the rad and welded all 4 corners and put on the truck fits tight and moves some air . mow need to close off the top of the rad to the rad support
74 Shortbed
Pretty tight fit, looks good though.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Interesting..but whats the string for?
74propu
florida
austin
5.3 / ?/454 tbi
the string was used for pulley alignment and belt size
78silverado
