crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
Aint it great when a plan comes together?
Sweet, cant wait for pictures with the 4". Im having a hard time finding a truck on 4" lift with 35's. I need a picture to show me what my truck will set like.You must be registered for see images attachFinal product....can't drive it yet though...rubs BADLY in front (only a 2" lift on now). Sigh, 4" lift coming tomorrow.
Looking good...
but ditch those cinder blocks!
Looking good...
but ditch those cinder blocks! Obviously they worked for you- but can crumble in an instant. A friend of mine used to work for the fire department and had stories of body recoveries from failed jacks and broken cinder blocks.
Fill the cinderblock full of concrete, then put a peice of 2x6 or 2x8 over the top between the stand and the block.
Ok, other than too many cinder block orientation comments (blocks were changed shortly after taking pic due to realizing they were placed incorrectly)...the job is done.
Steering creaked constantly and was hard to control when I hit any bump.....removed driver tire, drive shaft and housing...new upper & lower ball joints...problem solved.
Leaking fluid from front differential....pinion seal bad. Replaced that today too.
Tightened steering box gearing....drives like a different truck!
4" rough country had to be added to clear tires after this pic was taken....toooooo much rubbing otherwise!
JH
Sent from my iPad
