Auto to Manual
disenough
Rock Hill SC
brice
I went from a sm465 to a nv3500. I know th3 nv3500 is nowhere as strong but the shift like a Honda
instead of a dump truck.
Josh Helm
Mooers New York
josh
K1500
5.7 vortec
why does everyone refer to NV's as not being strong? I am wrapping up my restore and am going with a 3500 but am a aggressive driver ..hopeing it'll be fine
CSFJ
When compared to a m465, very few transmissions are strong. But, the NV unit was designed as a truck trans and should be fine behind a mild v8. The m465 just gained a reputation for invincibility as it was common to find them in heavier commercial vehicles, like dump trucks.
Josh Helm
Mooers New York
josh
K1500
5.7 vortec
ahh I see ..cause I seen many no so "'strong" trans take extreme licking and keep ticking ....ill be running bout 450 HP ahead of my Nv 3500 ..should be ok and it has no miles and is the last gen of its production years
CookieSoup
Seattle area
Suburban
I agree but im diesel soooo shifting like a honda would be nice but its still slower then a turtle
roundhouse
atlanta ga
justin
77,78,79,80 ?
The 3500 is Probabaly the best Manual trans to use behind a a 6.2
The 97-07 models were the strongest
We bought a used one from a wrecked truck that was used in a rock quarry
And it’s been behind a 5.3 on 35s with a teenage boy driving it for three years with no problems
The earlier years had issues with jumping out of first gear
CookieSoup
Seattle area
Suburban
i hated my NV3500 in my 07 silverado thing wouldn't shift to save its life.
WarlVlachine
WI
Robert
if the price is right and they weren't rated very high for input torque.. just as a far warning but dodge used the same design and haven't heard much negative things ..so take that with a grain of salt .. I never had issues with it minus gear ratio is long 1 to 1 in 3rd and OD is .75 to 1
Is it the 4WD version?
Josh Helm
Mooers New York
josh
K1500
5.7 vortec
Yes as long as you have correct transfer case..
WarlVlachine
WI
Robert
Yeah, I have the right T case. I picked up the wrong trans though, 2WD model. What are you looking to get for it?
If something worked out, I'd have a great condition 2WD NP833 for the OP. :happy107:
WarlVlachine
WI
Robert
2WD
JWDynamics
Rowlett, TX
Jeff
That NP833 sounds like it would be a perfect fit for me. Does this site have PMs? I'd like to know what you're asking for it.
roundhouse
atlanta ga
justin
77,78,79,80 ?
My teenage son bangs Thru the gears in his with no problem
And I pound the one in my bronco
It’s one of the early versions that jumps out of first gear
I have a replacement trans
So I’ve been trying to break this one and I just can’t break it
I also have a replacement roller cam EFI 351w
So I’ve been trying to blow up the efi 5.0 that’s in it now
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
My 700r4 just blew and am thinking about a manual swap since i was about to swap a vortec 350 in anyway.
What would i need for the manual swap? I need overdrive so i guess a nv3500 or 4500 would be the best option? I dont tow or anything so the OD and "honda" shifting sound awesome.
Sent from my SM-G920V using Tapatalk
Andrew1
