Auto to Manual Tilt Column Modification
Ronno6
South Mississippi
Ron
I would like a tilt column in my 84 C10.
I have a floor shift.
Is it possible and how involved it it to remove the shift collar from the auto steering column and replace w/manual collar ?
Is it doable at all??
Or, not worth the hassle??
Interesting to note that my '79 to '84 illustrated parts manual has NO '84 drawings whatsoever........
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Been so long since I worked on these I am not 100%, but my thought is no, not readily doable.
My thought process is that the mast jackets are different.
The manual would not have a rotating shift bowl like the auto does, and you would also need the key release mechanism to do it OE style.
If I am wrong, hopefully someone will chime in.
Britt
Btw - found this cool link :
https://www.google.com/url?sa=t&sou...FjAAegQIAxAB&usg=AOvVaw1HnAfw09ZaqV_ofMWOEUYQ
CoggedBelt75
Oklahoma
Joe
Might try this....
Ronno6
South Mississippi
Ron
Might try this....
Yessirree. Seen that one a while ago.
That cleans up the shifter nub OK.
I may have to go that route.
Thanks.
Ronno6
South Mississippi
Ron
Got a (hopefully) good deal on an auto tilt column.
I may rework as above to remove shift lever bump and tack weld the shift lever at the bottom.
brentjo
