- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I meant only about he bell housing. The only parts, to my knowledge, I have are the bellhousing, a fork, and a rubber boot, and a cover plate/inspection cover with a starter cutout on it.Yeah, a manual will have a big spring on the inside, a mess of linkage, a plunger rod that goes through the floor, and the linkage physically interacts with clutch/throwout arm.
In a Hydraulic, the pedal presses a plunger that goes into a single port clutch master cylinder, from that, there are lines that go down to a hydraulic slave cylinder, the depresses the clutch throw out arm.
It's easy to tell, they look totally different. Just look for a reservoir under the hood that says clutch. If you have one, you have hydraulic.
The bell housing for a hydro will have a bracket to hold the piston. A manual bell housing will not.
Check out the pics I sent a while back, you'll see the difference.
I can look in the box but I never found a hydraulic reservoir but I never looked either. But my grandpa almost exclusively chopped trucks that were damaged or destined for scrap that he found someome willing to part with it usually from work buddies(he did labor work in various fields over years and had a lot of connections
old friend Dan who’s 13 year old truck ate a guard rail after being t boned by the unattentive driver right at the drivers fender would be a very possible scenario why I may not have any hydraulic parts on the engine side but the engine/trans were okay etc
didntn happen but it was example. I’ll look for these pics. I saw something in here one day about clutch pedals having 4 studs instead of two or something and I thought it was weird because mine have 4 that I have laying around but I didn’t verify that anywhere
so, if I see your pics if I think I have similar one oh boy money
