PhotonFanatic
- Aug 6, 2022
- Arlen, TX
- Wilhelm
- Silverado
Are the front wheel bearings adjustable when they get old? Or get some miles on them. After a thorough inspection of the front suspension and steering on my truck, it seems that it needs a steering box and wheel bearings on both sides. All of the ball and socket joints are tight. The pitman arm has a small amount of play in it, but it's quite small. I question replacing it until it gets worse.
Even though everything seems tight, the wheel will clunk when you rock it side to side, and up and down. The truck also acts like it's got a mind of it's own, and wants to begin changing lanes for you. So before I go replacing all the bearings, I wanted to ask if there's any room for adjustment. Maybe tighten the castle nut a couple of turns. Good idea, or bad?
