Are front wheel bearings adjustable?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Or does it also get set when you tighten the nut on the front?
^^^^ this
When you tighten the nut you are adding load to both bearing sets because they oppose each other.
If it rocks when you push at 3 and 9 it's tie rods,if it rocks when you push at 12 and 6 it's ball joints. If it rocks at both,it's wheel bearings,or tie rods and ball joints.
Scott91370
Burleson, Tx
Scott
Sierra1500
Hate to disagree on the interwebs but I’m gonna…
Shot bearings can “clunk” in every direction
I don't see it as a disagreement, I see it as I left that out.
Should be: All directions - bearings or ball joints.
Auburn, Washington
Anyone know how much it costs to have a mechanic do this job? Goofle says $50 - $300.
I'd like to do everything myself, but I don't have a torque wrench to set the bearing pre-load. And I don't trust the rentals when it comes to a torque wrench. It's probably been dropped 100 times. So if the cost of the wrench is cheaper than paying someone to do it, then I'd much rather buy the wrench and do it all myself. These days you can get a good digital torque wrench (Gearwrench brand) for $200.
Never used a torque wrench on traditional wheel bearings ever.
Get em good and snug to take out any slop. They should roll with a bit of interference at this point. Then back off to loose and hand tighten, if no perceptible slop or play and no interference when spinning the wheel like you felt earlier, you’re good.
If you’re between notches to lock it in, hand tight, go tighter rather than looser to lock it in.
BrokeDaddy
