Anyone used the old ash tray for something (else) that's interesting?
Swims350
Logan WV
none
my ash trays are always full of change kinda like a small emergency stash of cash
a cash tray
that's every ash tray my old man has ever had in a vehicle lol. anything from singles to 5's and change. Although he smokes and still uses them too, kinda makes the money nasty to mess with lol.
I've seen guys mount a gauge in thee before.
I am thinking about sticking my tach in that spot
Green79Scottsdale
G.R. - MI
Bob
Occasionally, while making a repair or testing a transmission, I need to refer to a tachometer. But unless it is incorporated into the original instrument cluster, I don't want to see one in the cab.
Any mounting I've ever seen looks out of place and makes the owner seem like a wannabe drag racer.
This is the ashtray part:
If you like to watch your RPM's and are looking for a place to mount a tach (but don't want to alter the stock layout of the cab) , consider pulling the ashtray and mounting one on the backside of the door.
Sunpro makes a nice tach with a 2 5/8" dial that should fit perfectly.
Open the ashtray door to monitor RPM's and flip it closed when done.
This was a spot I had considered when I was in the process of putting my tach somewhere. At the time it seemed like I would either have it open all the time to see it, and/or it was just a inconvenient place to reach for and look at for my RPM's as I am rolling down the road. I am actually using the small SunPro now, it is at the bottom of my dash, and admittedly not the best location either. Maybe I will dismount it and see how it would do in the ash tray location.
Green79Scottsdale
G.R. - MI
Bob
They do make a nice 2 5/8 tach, but you will need to modify the top portion of the stock door. I tried fitting mine there, so close, but no banana. If you don't mind modifying yours, it will work very nicely!
How about Autometer's 2 1/16" in-dash:
You would have to fabricate a bezel to mount it through - but it would look sharp.
Green79Scottsdale
G.R. - MI
Bob
That would probably fit perfect. I almost got that one instead of the SunPro because I was thinking about putting it in the blank spot of my cluster. Just as I was about to order it, I found a tach cluster that I ended up getting. I still wanted a tach until I got the tach cluster ready, so I bought the $30 SunPro, instead of the $100+ Autometer.
That Autometer is almost perfect. Only goes to 5k RPM's, which is all I need, and the font is almost identical to my '79.
HA - I had no idea they went for that kind of $$$.
Guess we can cross that off my wish list.
This is making me want to do some cool stuff with my ash tray! I like the on posted with the USB port in there :popcorn: I wonder if my radio could be modded to accept tunes from a USB??? :popcorn:
I see one of my boys do this all the time. Never really paid too much attention but I think he just cuts into the lines before the amp and solders in a USB pigtail.
Don't quote me - I'll check.
I checked, what he has been doing is splicing in a connector that accepts the output from an Ipod/Iphone. Is that what you want to do?
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I put my glock 21 in it...fits snug dosent move anound its in a uncle mikes soft holster..ive seen that cup holder thing that would be nice. Im always spilling soda on my seat
Arrover
NW Arkansas
Adam
GMC Crew Cab K3500
I don't smoke so I cut the upper screen type thing and the little hook in the lower corner out of the ash tray. Then I sprayed the inside and the part of the outside that you see with Plastidip. It makes a great place for my iphone (or whatever). Plastidip is a very cool removable rubber coating. It's pretty amazing stuff. People are coating whole cars with it now. Anyway, I think the spray cans are around $8 at Lowes.
Good job
Hoodbj
Billy
R10
Older post but a backup camera or navigation system would be cool here also. I plan on ordering the cup holder from lmc also to help keep my junk dry.
87ChevyR10
Kansas
NA
NA
NA
These are some neat ideas! I like the hidden tach option. Although, my tray won't stay closed and hangs a lot lower than it should. I'd consider using black duct tape to tape it close. I don't have a use for it anyways.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
you need the spring reinstalled on the side
GorillaHumper
