Anyone use these Littelfuse zcase terminals before?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
RanchWelder
Earth
Blazer
355ci
Yah. Marine Rated Battery Fuse. MRBF
This is a 600A SkyCraft surplus buss bar, mounted to a slab of mud flap, isolated from the firewall with a rubber inner tube protective flap/shroud.
Hanging the fuses from a chunk of mud flap keeps the rain and mud off the circuitry.
Only the top 4 stainless screws penetrate the firewall or the inner tube shroud.
All my wires incorporate a drip bend in the wires, from the bar back up to the firewall harness areas, the battery(s) or the alternator.
This is a drip-dry downward wiring configuration.
You could make a plastic housing for it as well, if neatness matters.
I would refrain from the metal box, unless you know how to ground and insulate it.
Suite yourself.
MRBF ice cube fuses:
Dual lug, no fuses in picture:
(2 different rated fuses on 2 separate 3/8" lugs from the buss bar).
Bay Marine:
https://www.amazon.com/gp/product/B075ZGR96T/
Single lug with fuse in picture:
https://www.amazon.com/gp/product/B07LC6B7DR/
These are widely used for marine applications, so they work in very wet conditions, by design.
You can find spares at any US Marine store or marina.
They are everywhere.
https://www.mouser.com/c/?q=Eaton Marine Fuses
My battery feeds the bar.
Bar has 4 small 10/24 screws for additional 12v/12ga wiring connections on both sides, which the cheaper 300A units do not have. 3/8" high grade stainless hardware, double nuts with locks.
Very convenient.
The plastic housing the cheaper units have do not really protect the circuits very well.
My mud flap inner tube mod may look red-neck, yet it's very effective.
My 4ga alternator feed hits the buss, not the battery. (10ga is standard).
The 2 x 4ga battery jumper cable wires are crimped into a 2ga copper ferrule to the battery.
Found jumper cable wires in the trash, with broken terminal clamps.
600A is plenty to run a second battery/isolation, a second alternator, a welding machine, an on board compressor and a 12,000lb winch without a hiccup under multiple loads.
My PowerMaster alternator is 220A with adjustable charge voltage for lead acid, AGM or Lithium batteries.
Overkill is the minimum standard.
Normal standard is sub-standard.
You might consider:
Move the connections from the top of your battery for safety and ease of replacement.
All that weight on the positive terminal, from the Mouser Part you suggested, can break the battery lug or cause a short way too close to the caustic chemicals in the explosive black box. Way too much going on where you lean over the engine bay with a sweaty shirt in the hot weather.
It will work. Not the way I went about it. Gave it some thought though.
If you accidentally bump that thing with a c-wrench to ground, you'll know it.
Cover your terminals at the battery with as little terminal there as possible and move your junction to where it remains high and dry?
The Fastronix Mill Spec terminals:
I'm not certain SkyCraft has any of the 600A bars left at $65.00. At that price they went very fast.
300A imported bars are double that price for inferior quality/poor hardware.
Not even sure they are solid copper.
*If YOU tap and machine some of these 4 lug solid copper buss bars, (on request), for a few of the 4wd members here you might make a few bucks to cover your expenses?
Find yourself a chunk of copper bar stock and tap/machine the buss bars?
I'll bet the rock crawler community would buy them too.
Mud flap to mud flap would work, instead of the plastic part the SkyJunk part had.
It has very little insulation properties, really.
Slab of G-10 insulator block would work excellent. $$
Much better than cheap plastic base.
If you want the exact dimensions of the copper bar, email me.
Good luck.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I just received the items today. It appears that the stud’s insulator also acts as a spacer or support for the bus.
Anyhow, we’ll see. Everything looks quality.
RanchWelder
Earth
Blazer
355ci
It's cool.
If you're good with it then make it rock.
The covers look like they work well.
I was wrong about the 300A bars they are as low as $18.00 now.
And they are not copper.
All the plastic base materials insulate and hold the bolt head from turning.
Try not to over tighten or they can break loose.
You know where to find spare fuses for around $16.00 each.
The clear cubes are a bit easier to see when they are blown, is all.
If you can brace the wires from beneath the tray or from the fender well with a make shift bracket to take some of the weight with a few zip ties, it will work awsome.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Rerouted the cable from the alt and l/r batt crossover, as well as the larger fused loads. The way they’re routed, there’s negligible pressure up or down on the terminal.
Fastduramax
Uranus
K10 Silverado
Great find Jeremy I just ordered 3 ! I'm mounting a winch to my 10 ton trailer and NOT running an auxiliary battery, this will be way handy for the Smittybuilt wiring harness I'm going to utilize...
RanchWelder
Earth
Blazer
355ci
The location your battery lives, is ideal for this unit.
So close to the firewall, it's really the same as the firewall mount.
Most of the Square Body's have the battery with reverse poles sitting very close to the core support. All the wires would be hanging in the breeze.
What year square body it that rig?
Your installation looks excellent.
Now it's time to get it dirty!
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The location your battery live, is ideal for this unit.
It’s my 04 Cummins.
My square had a dual battery, but was converted to a single battery in the front passenger area just rear of the core support. It is side post, so I went straight through the tray with the cables and located the junction and fuses below the tray area. I’ve got some ideas how I’m going to rework the wiring a little on that truck this summer when I install a winch and small stereo. Here is the current setup with the battery out, you can see the wires in the top left corner.
Obullard74
