- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Does this process hurt machined surfaces?
It works with anything that is metal, steal or iron. Bike Frames, Fenders, intakes, blocks, heads, plumbing pipe, whatever your heart desires. BUT DO NOT USE THIS PROCESS ON ALUMINUM. It will literally disolve soft metals like gold or aluminum. So don't be doing a write up for us on your Edelbrock Air Gap intake or Carb.You put that stuff in this process, you go back to check it, the stuff will be gone. It will be disolved in the water.
Ok, I have a rusty 64 390 4bbl intake w/filler tube off a T-bird that I bought for 30 bucks. I wish they made metal tub/pan big enough to do a radiator support. Wait, They might at farm center.
Im not sure if you can use the big galvanized live stock watering tanks, unless you could just use the actual tank as your electrode. THoughts on this hot rod?
It would be sweet as hell to get one of those huge 5k gallon polly tanks that lay flat pancake style and cut the top out of it. You could strip entire fenders and maybe even cabs.
You mean 55 gallon poly drum??? That's what I use. You can buy them here for $3 a piece. Just have to clean them out. And they are easy to clean. If usually got detegerents or stuff like that in them from a coin op car wash. Not hard to clean at all. I used them for gasoline for awhile and they worked great. Don't even think to ask why I needed them for gas, I'll never tell.
So do they just trap rain water then and filter it???
Called a cistern, plumb yer gutters to it, catch rain water for worshin clothes and deeshes, flushin tha *******, givin tha young'ns a bath...saves the well water for-a drinkin! Yep. I be a redneck.
