So after cleaning the electrode, and pulling out the block to check its progress, I was amazed at the difference. But still a little more rust I wanted off, so I put it back in with the cleaned copper electrode and let the process run for a few more hours.
Keep in mind, there are other tips and tricks that improve the process, but doing on differant items at differant levels, like this being the big one, and many parts in 5 gallon buckets, I find its an experimental process. You have to try differant things to find what works best. Some basic rules for example, DO NOT USE aluminum for an electrode. It will melt. I hear Stainless Steel works best. You can use anything as an electrode. It does not have to be copper. Some people even use a large bolt when working in a 5 gallon bucket to clean brackets. The process is cheap. Just have fun and experiment with it. I know it works.
