Anybody see one of these before? Little Max
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
So a friend of mine gave this to me for my suburban. Pretty cool old school inverter. Anybody ever seen one or know on how to hook up?
Midnightmoon
Pennsylvania
Justin
Not the same model, but there used to be something similar in an old fire truck that our department had back when I joined in 1991. It was an early 60's tanker/pumper combo and had a similar style module in the radio compartment by the pump panel.
Originalthor
Scott
Suburban
Its quite interesting and has so many wires. Theres eons of new technology in the inverter world these days but thought it might be cool to put in my truck and I like old school things.
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
It took a minute for this to register in my brain, but what you have is actually a control panel/end point receptacles for use with a special alternator... Note that the label on the side says that it's for use only with MJC-6c (and a couple of other similar alternators only, and that its output is 110vDC (instead of AC) And also a command to only operate switch at idle. Outside of a couple old tube radios I have, and incandescent lights, I'm having a hard time coming up with much else that'll operate off of line voltage DC.
It's a really cool looking piece of vintage gear, but without the alternator that mates with it, you're kind of stuck in the weeds.
Originalthor
Scott
Suburban
Thanks for the info on it Ellie. I thought is was something you would see on a cucv. I kinda figured it would be a obsolete piece but cool to put on a wall of fame that I got going.
350 w/203
You don't want to get bit by 110VDC. Your friends will surely buy beers for your widow and console her in other ways.
Originalthor
Scott
Suburban
I've been jolted a fair bit back in the day when I was working with a good old Ukrainian electrician. He did everything live darn near but neglected to tell me so I would go to hook up stuff and strip wire and It was a rude awaking but you learn from the best and always play with wires like there live cause you just never know if someone turned on that breaker without you knowing.
350 w/203
The Ten Commandments of Electrical/Electronic Safety
I. Beware of the lightning that lurketh in seemingly uncharged
capacitors lest it cause thee to bounce upon thy buttocks in an
useamanlike manner and cause thy hair to stand on end, therby exceeding
regulation length.
II. Cause thou the switch that supplieth large quantities of juice to be
opened and thusly tagged, that thy days may be long in this earthly vale.
III. Prove to thyself that all circuits that radiateth and upon which
thou worketh are grounded and thusly tagged, lest they lift thee to radio
frequency potential and causeth thee to radiate with the angels.
IV. Tarry thou not amongst those fools that engage in intentional
shocks, for they are not long of this world and are surely unbelievers.
V. Take care thou useth the proper method when thou taketh the measure
of high voltage so thou dost not incinerate both thee and thy test
equipment. For verily, though thou hast no NSN (National Stock Number)
and can be easily surveyed, the test equipment has one, and as a
consequence, bringeth much woe to thy supply officer.
VI. Take care thou tamperest not with interlocks and safety devices, for
this incurreth the wrath of thy department head and bringeth the fury of
thy Commanding Officer on thy head.
VII. Work thou not on energized equipment without proper procedures, for
if thou dost so, thy shipmates will surely be buying beers for thy widow
and consoling her in ways not generally acceptable to thee.
VIII. Verily, verily, I say unto thee, never service equiment alone, for
electrical cooking is a slow process, and thou might sizzle in thine own
fat upon a hot circuit for hours on end before thy maker sees fit to end
thy misery and drag thee into his fold.
IX. Trifle thee not with radioactive tubes and substances lest thou
commence to glow in the dark like a lightning bug and thy wife be
frustrated and have no further use for thee except thy wages .
X. Commit thou to memory all the words of the prophets which are written
down in the 300th chapter of thy bible which is the 'Naval Ship's
Technical Manual' and giveth out with the straight dope and counseleth
thee when thou hast suffered a ream job by thy division LPO (Leading
Petty Officer).
Dan Brown
Katy, Texas
355 (.030 over 350)
I used to have one similar to this one. As I recall it came with the equipment so that you could actually weld with it, too.
SquareRoot
We call him "Sancho" in these parts.
  • Like
Reactions: WFO
Originalthor
Scott
Suburban
Really m. That is very interesting. I always wanted to do a weldanator since I don't have ac. And put it here like this
drowe14
