Any good hacks/upgrades you've come up with for our trucks
77 K20
Montana
K20 5" lift
HT383 fuel injected
Yep, bolts right on with the correct bolts. More power and less amp draw.
A good example is my '78 Burb. It had a fresh reman starter, manifolds and a good strong battery. It had heat soak issues and it had a very hard time cranking the 454 over when hot. I put on a good used 'vortec' style starter, a set of headers and also had to install a weaker, older battery. It cranks right over at all times now.
Just in case people haven't seen the vortec style next to the stock starter: Notice the dual bolt pattern for the vortec style starter. It will fit both size flexplates (153 tooth vs 168 tooth)
I did however have to modify my flex plate inspection cover. Stock was just a round/semi circle. The new starter has the square "block" and so needed a "square hole". Guess the correct way might be grab a inspection cover from a newer vehicle from a junk yard?
While similar in size, that's not what GM used on the vortec motors. I have a picture somewhere...
77 K20
Montana
K20 5" lift
HT383 fuel injected
Oh... that's right... its coming back to me now. I was going to go with a vortec style one, but chose that Chevrolet perfomance gear reduction starter because of the dual bolt pattern for both flex plates. My new engine had a smaller flex plate than my old 400.
:shrug:
:shrug:
There was also a straight pattern version of the "vortec" starter, it was used in cars with the smaller flywheel. It was used in the B-body, F-body and I think the Corvette too. I believe it went into production much sooner too, with the LT-1.
Top left is a 168 tooth starter
Bottom left is a 153 tooth 305 style starter (for 5-speed iirc)
Top right is a hokey Jeg's starter
Bottom right is the 168 tooth "vortec" starter
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
The more i look at this vortec starter talk i think i may upgrade my huge old one to a vortec and see how much faster it really does spin. May end up too fast with my 1100 CA battery.
Rusty Nail
Rusty
350sbc
Dang! You sure got a lot of starters!
Looks like you need more engines to go with em all..
:p
Doug13
Ringgold Geroiga
Doug
Surbanban
350c.i.
Hello guys , Dougnsalem wanted me to repost the barn door straps i made for my Suburban. I took some old seat belt's and made some door straps out of them . I measured the length I wanted and I cut to fit . I used 10 pound test fishing line to sew them up .
eskimomann209
Modesto
Marcus
You could order limiting straps for that
We use em on 4 links
https://www.amazon.com/DOUBLE-LIMIT...ting+strap&dpPl=1&dpID=41tM-ERM5bL&ref=plSrch
thatgermanguy
