Toad455
- Aug 3, 2023
- North Texas
- Kevin
- C10
I posted a question a while back about these plastic shims but that was before I took my springs apart. Now I see there is a hole on each end of one of the leafs that had a plastic shim that snapped in place. The pass side had the little plastic nub broke off so the shim scooted away from the end, there is wear on the spring from them rubbing together. The drivers side doesn't have the wear since the plastic shim is still attached. This is on a 78 C10 Scottsdale that has never been took apart before, I've known the truck since new. Any ideas on where to get new shims like these? I've looked at LMC and every other place I know and found nothing. Without the nub they won't stay in place. May be fine without them but there is a little wear where the shim slipped off.
