another elco
yevgenievich
Place
Name
Year
Model
Size
Even more of a rust bucket this time, and autotragic
I liked your old Elco, but damn! This one is way cooler!
What's under the hood?
yevgenievich
Place
Name
Year
Model
Size
It is mostly stock. Guessing 307 but might be a 350 motor. Nice 454 badge and a failing th350 or th250 transmission(actually rattles and whines when in gear and a big delay going in to reverse). Headlight wiring has issues, oil leaks, broken window regulator, numerous missing trim pieces.
But did make it 70 miles home. Well, somewhat home, I did not have space in my drive way at the moment.
Catbox
Peter
C20 Silverado Camper Special
Ohhh I like it.
I am sure you will have it torn all apart and in better shape in no time.
RoryH19
Rory
R10 Silverado SWB
Looks good.
How many cars do you have?
yevgenievich
Place
Name
Year
Model
Size
Looks good.
I have sold some recently.
Turned out window regulator is fine, but vent window regulator is broken so ordered a new one. Fixed the door open button and then found that it came with new door handles. Motor has been decked before, so still not 100% if it is 307 or 350.
Also trans pump makes rattle noise under load.
Most of the car appears to have been silver, driver side door is different and front sheet metal used to be green.
yevgenievich
Place
Name
Year
Model
Size
It had a scrape on rear quarter that pushed the taillight out. Took it out and bent the mounting bracket back for it to mount correctly. Floors behind the seat are made of rust, so have to make something work there. Ordered 3 point seat belts for it as well.
Cool project:)
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
It's been de-choked!
woah lol
Does the front or rear glass leak?
Cantrell299
