Ammeter/voltmeter gauge suddenly quit
84K30
SWPA
As the title states, my ammeter/voltmeter gauge decided that it did not want to function anymore. A quick search on the google box seemed to suggest that this gauge obtains its reading via the printed circuit on the back of the gauge panel...is this correct? Or is there a sensor somewhere that I can test and/or replace?
Truck is a 1984 K30, Scottsdale trim, 454, 4 speed manual and does not have a tach gauge cluster.
-Eric
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Yes, it gets its reading from the instrument panel voltage.
84K30
SWPA
Copy. Looks like I'll be taking the gauge panel apart then. Thanks!
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
Possibly a lifted or broken trace on the circuit board or the meter went kaput.
hoagster
California
K10, 1500
5.3l
cold soldier joint or broken, when you find the wire to the gauge to can re-soldier on just about any trace on that board. or Change it out and tie in to the alternator for a real reading. amd or the meter went bad like @jake wells said
350 w/203
Disconnect your ground wire at the battery first!
seanhatesregister
