Aluminum side molding removal
WFarm
Central Virginia
K5 Blazer
Any tricks or special tools for removing the aluminum rear side molding on my 75 Blazer? I remove the screw back by the tailgate and can easily slide the molding back a few inches until the front end hits the clip. How do you release the molding from the clips without destroying anything?
There's one or two spring clips that push into a hole in the body, the rest of the 'clips' are flat pads with 3M tape on them, which need carefully removed with a razor blade.
WFarm
Central Virginia
K5 Blazer
I don’t see any 3M tape, but can get a peek at the metal clips. Plus seeing as it moves back and forth freely until the “closed” end up by the door hits one of those clips would indicate it’s not taped. Don’t know how to get those darned clips to release without breaking something.
Also found this old thread
WFarm
Central Virginia
K5 Blazer
Thanks Zach. I had found those videos before I posed the question here. Thought they would help but in the removal video he does not show the bedside trim. That straight piece above the front tire is exactly how my long bedside piece is mounted, but the bedside piece is closed at the front end so it won’t slide over the clips. Nothing is glued.
I’ll keep pokin around and see what I can break. :banghead:
Yeah, I guess those weren't specific to the bedside. I'll try to remember to ask one of our R&D guys tomorrow, he's test fit our new trim. I'll see what he says about how to get the old off without hurting it
WFarm
Central Virginia
K5 Blazer
Thanks Zach. I’m going to look tonight and see if there is a way to carefully open the closed end of the trim piece. If the end can be opened the whole piece will slide right off the clips. Other than that I’ll wait to see what your folks might suggest.
The square pads with the 3M tape are able to slide within the trim. That's why you'll commonly see a truck with several screws in the bedside trim. The tape deteriorated and let go, then the owner ran screws into the trim so it didn't fall off.
If I were home, I could provide picture examples of K5 bed trim... but I'm several states away.
Didn't get up to the shop till nearly 2pm yesterday cuz I was junkyarding and the guy I was gonna ask was gone. But I axed him today and he told me there's a spring clip front and rear of that bed trim piece. This is a pickup, we're not sure how the blazer's are and our one early blazer is a stripper model with no trim. Here you can see the holes for the trim clips. Unfortunately, if your blazer has one of these up front, it has to be popped out of the bedside for the trim to come off. In a truck, you can reach up between the inner and outer bedsides with a really long pair of pliers or a skinny arm and pinch the clip nose closed. I don't think you have that option on a Blazer
Here's the relief in the trim I was talking about for the clips
It's in between those two clips, about a foot from the rear of the trim
And these are the spring clips
Auburn, Washington
So if you pop the clips front and rear will the trim slide off the stick on clips or does the sticky foam need to be cut? Like with fishing line.
I don’t know but I need to replace the trim on the 77 one of these days and I’d like to save the good pieces that are left.
If it’ll slide, yes. Sometimes, they don’t wanna slide and get stuck
F1r3truck
