1987 GMC Jimmy
Automobile Hoarder
- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
I’ve got the smallest A/C leak in the history of A/C leaks and wanted to see if y’all have ever had this happen to you. When the positive pressure slips below a certain point, the leak stops. Not enough pressure to kick on but doesn’t go totally empty. At rest, it reads 20+ PSI on the low, 25+ on the high. This is partially good because I know my new accumulator and o-tube aren’t ruined since it’s not open to the atmosphere, but it’s impossible to find the leak. It takes a few days to a week for the leak to stop. It’ll hold vacuum indefinitely so I know I need positive pressure to find the leak.
I don’t know if there’s enough leakage to register on an electronic refrigerant sniffer that I don’t currently own. I’m very hesitant to use compressed air and soap bubbles in this moisture-laden, Southern air but worry it may come down to that. Nothing found with a UV leak dye, and the R-134a o-rings, adapters are all new. What would you guys do? I don’t want to arbitrarily replace parts because everything works well, especially the compressor.
