A very expensive and dumb mistake (update I was wrong)
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
finally mocking up the drivetrain after setting the engine transmission and transfer case and then I saw it. I guess I just got excited about doing a one ton swap into my 87 square and just simply bought the wrong rear end. I already have 5.13 gears, arb air locker and disc brakes.the spring pads have been cut, moved and welded to fit my truck and it will not fit. I am sickened. I want to throw up. I am off the complete width of my driveshaft. This rear end is offset and not centered like I need. Will someone please tell me exactly what 8 lug full or semi float that I need to make this work please.
Here is a picture of my bowl remover.
After taking a few breaths and LISTENING to people who know better than me I jumped the gun by stating that I had made a mistake. Several of you said send it. And then one particular reply was there are hundreds if not hundreds of thousands of squares running a 14 bolt rear swap with the same setup as me. And he was right. The drive shaft was installed with the bastard conversion u joint and it’s hardly even noticeable. But it is very short! I need either a new shaft or have mine lengthened. Anyway thanks for all that replied. I really do appreciate your time and knowledge. Here are a few updated pictures. I also found my Milwaukee adjustable pliers while lying on my back and looking up.
Why not just try running it? I can't think of what they were off hand, but I know there have been factory built trucks with an offset pumpkin.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
It would be way off center. This rear came out of a 03 2500 I believe. The yoke and pinion are off set instead of centered like I need. I don’t know what I was thinking. I had no idea it was like this.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Talked to the original owner of the rear end. Said it was perfectly normal to be offset by that little bit. No issues at all when he ran it on his K30. Same transmission and transfer case. Just got to use the bastard u joint in order for my driveshaft to work properly. Bucket you were right!!
nvrenuf
Mobile, Al.
All 14 bolts are offset like that and are in literally millions of squares. Don’t sweat it and run it.
Just to say it out loud, since the spring perches have been moved you might double check to make sure the housing (not the pinion) is centered under the springs.
ali_c20
Austria
Alexander
C20, K5
I have to measure the 14 bolt ff in my 74 C20, it looks pretty centered.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
So long as the angle at one joint matches the angle at the other it’s all good! No different than the downward angle from the trans to the pinion. I suppose it could make the phasing of the joints more sensitive to pinion angle.
Pinion and transfer case are both parallel to the frame rails, so angles at the joints match.
It kinda seemed like the entire pumpkin might be shifted over a bit? I dunno, I guess I've never paid much attention to how much of a side angle a factory shaft does or doesn't run at.
ali_c20
Austria
Alexander
C20, K5
Back from the garage, yes the pinion is offset. These are the measurement from my 74 C20.
I measured from the inside of the spring perches.
Perches to pumpkin: D: 8.2 P: 12.4
Perches to pinion: D: 20.65 P: 19.5
I learned something today as often in this forum:)
Auburn, Washington
Yes but that’s less than an inch offset so effectively less than half inch offset in the driveshaft.
If the OP pic is 100% correct, it’s off by about 2”. Seems excessive to me too. However at this point I would 100% bolt it up and send it and see how it feels and if good, see how long it lasts.
Again, context. It’s an old truck. If it’s going to be daily driven and u joints only last 10k miles, maybe it’s not acceptable to replace them every year or whatever.
If it’s like my trucks, a 10k mile u joint will be g2g for several years at the rate they get driven.
Nardulli
St Louis
C15
If the delta is too large, you might go to a 2 piece drive shaft. Take up half the offset output shaft to carrier bearing, and the rest carrier to diff yoke.
mrchevy
