- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
So if you have been following my cam swap with a/c thread, you know that I have pulled my engine out, put new heads, cam, intake, headers on it. Engine is back in, bolted to the transmission, engine mounts mounted. Putting the front accessories on and the a/c compressor is about a belt length too far back but the rear top bracket is got a 1/4 inch gap. Compressor has its original front brackets and top rear. Crank pulley lines up with water pump pulley without issue, that makes me think that those pulleys aren't suspect. Heads are summit racing sum-152123 with an Edelbrock performer 2101 manifold.
Sent from my Moto Z (2) using Tapatalk
