89S 350 TBI Head Gasket Replacement Project
Me too, they are really sharp.
FAIL.
I got a really bad miss in this motor, and I can't get rid of a valve tap. I definatley got at least one totally dead cylinder. All new wires, cap, rotor, plugs, adjusteed the valves 6 ****** times, 4 times by the book and twice by ear. I am really pissed off. Can a bad hydraulic lifter be causing this? :flame: :flame: :flame: :flame: :flame:
Old cap and rotor.
Video
This is probably a really stupid question but when you put the wires back on did you make sure and put them back to the right cylinder? I always get nervous when taking them all off like that rather than just one at a time (although you can't do that when replacing the cap).
Video
Swims350
Logan WV
none
you do know with those fel-pro gaskets you aint supposed to use any type of sealnt or glue at all right? but if you tried it and they still leaked I would glue them too.
I checked them so many times yesterday I could do it in my sleep. I got to figure out wtf is going on here. :sad72:
Only on the pass side I had too because it was leaking at the back, it think the cover is bent or some ****. Just temp until I get a new set of covers.
Swims350
Logan WV
none
bad lifter or bad cam. I never go by the book, throw it out, do a running valve adjustment and hope it works, if not then something is wrong.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Are you sure its lifter and not a rod knock.
My mechanic says it may de a wiped lobe on the cam. :suicide:
davbell22602
Bunker Hill, WV
I Dont
Have
One
Does the tapping noise go away when pressing the gas pedal or does it stay there when the gas pedal is pressed?
