gnuiver
- Jan 27, 2024
- michigan
- Gerald
- V10
Good morning,
My Wife bought me and 1987 Custom Deluxe V10, 350, with a nice plow for the Property up north. 92,000 miles. Been sitting for 14 years. Cleaned off the motor. removed the rusty Plugs and changed them. (no easy task) Smog pump and pipes have dissolved so I removed them, put a 25k resistor in place. New fuel tank, filter and pump. Cleaned the tbi and flushed the fuel lines. Cap and wires which turned into a distributer when both screws broke off for the cap. Exhaust is missing yet where it rusted through in front of the Cat. Battery in Cranks over no start but will run only if I bottle feed it. No signal to the injectors. 12.3 volts on the positive side, injectors open if i manually ground them. New ground strap on the back of the motor. Suggestions? Tried to externally ground the ECM no joy.
