87 tbi 350 popping at idle and running rich
devildogcummins
forney tx
william
c3500
Tested fuel pressure last week, key on 11psi before fuel filter and 11 at idle. changed egr valve and the popping has stopped at idle, if i give it a small rev it will pop out left exhaust still for 10-15 seconds, then idles smooth. still no codes. Have looked everywhere for a egr solenoid, but cant find one anywhere, mine is a 3 wire plug with a filter.
gmbellew
Kansas city
glen
suburban 1500
were the EGR passages clear in the intake manifold? are you sure the EGR valve is the correct type? there are positive answers negative backpressure valves. they look very similar, but they are not interchangeable.
you can test the EGR solenoid with a mityvac easy enough
gpw0911
North Carolina
Geoff
v10
My truck was doing the exact same thing except it was the passenger side doing it. It would idle fine and then every 10 seconds or so I would get a back fire out of one tail pipe. Check engine light was not on. I had just put on full exhaust and headers and then it started doing it. Come to find out the previous owner had the longer of the two spark plug wires going to #4 instead of #2, and when I put the wires back on after putting on the headers, I put the longer wire to #2 and started getting the backfiring. I suspected it was a spark plug wire causing it so I pulled them all off and re-did it, and that fixed my problem. Since you just did your spark plug wires, I bet you got a wire crossed.
birdj81
Ohio
Duane
r10
Hi, all my friends call me Bird. I've been a member for a few years now, but I haven't commented on anything until now. I had this same problem when I rebuilt my 305 years ago. I put everything new into the motor after having to have it bored 30 over. it had the same problems and, after looking at everything, it turned out to be a crappy, brand new $150.00 distributor. I replaced that and it has fired up perfectly every time since then. Not saying that's the same problem your having, but it is something to consider.
bdlong07
