87 brake lights
Wallace6
Wyoming
Ray
Suburban
Ok so I have no brake lights, my blinkers work and so do the tail lights, what would cause that? Apparently bulbs are fine? Also the hazards don't do anything.' Are these connected in some way?
Thanks
Turbo4whl
Downingtown, PA
Wayne
Brake lights and hazards fuse are always on. Did you check the fuse? Power from the fuse box goes to the brake pedal switch, then to the turn signal switch. Since the turn lamps work, the issue is from the fuse box to the turn switch, which could also be the problem. Check the easy things first.
Wallace6
Wyoming
Ray
Suburban
I'm guessing since I have no hazards the relay is bad? I will try switching it and checking the fuses in the morning.
Thanks
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Before doing anything, push/pull the hazard light button a few times, see if that get all the lights working.
Find the brake light switch at the brake pedal. Use a 12 volt test light, make sure you have power on the orange wire. If not, double check the stop lamp fuse.
If you have power, test for power at the white wire at the brake switch WITH the brake pedal pushed. No power? Either the switch is defective, or out of adjustment.
If you have power, check for power at the white wire of the turn signal switch connector with the brake pedal pushed. No power? There is a break in the white wire somewhere between the brake switch and the turn signal connector. Start looking for a spliced wire m, especially if a aftermarket brake controller has been installed somewhere in the past.
If everything checks out good to this point, press the brake again, check for power on the green and yellow wires of the turn signal switch connector. No power? Replace the turn signal switch.
Wallace6
Wyoming
Ray
Suburban
So I ran through the fuses today and you were absolutely correct and thank you
F1r3truck
