86 1/2 ton gears needed for 33” with new 383
1986Chevy
california
Joe
K10 4 wheel drive
So pulling the trigger on a 383 with the 700 R4 had it rebuilt with corvette servos with 2000 stall converter and transfer case Np208 rebuilt was told the current gears are 273 with running a 4” BDS lift and 33” KO2 what gears and brand would you all recommend? Any advice greatly appreciated
Auburn, Washington
Guess I’d verify what’s in it first lol. Totally possible it had those originally though.
Like most of these type of questions, it up to you to decide what you want out of the truck. Mud bogger vs pounding it 85mph down the highway frequently beget different gears. Both fir out of the gate and for cruising speeds and your rpm tolerance at speed.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
3.73's at the very least. Probably 4.10's though.
I'd say you'd most likely be okay with 3.73's with a fresh 383.
Like said above, it depends what you're doing with the truck.
1986Chevy
california
Joe
K10 4 wheel drive
It came with 273 was thinking 373 or 410s will be using as an almost daily driver and do travel up the mountains from 1500 ft to 8000ft most weekends snow, ice in normal winters haven’t had any this year and mostly desert and mountain 4 wheeling in the summer highway driving to get there so I guess something for four wheeling and highway
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
4.10's I would probably go with. But that's just my opinion. You don't want to have to regear twice
I guess I should elaborate, it absolutely sucked on the interstate. The gearing was too tall, any little incline or the slightest headwind would require enough throttle that the converter would unlock and and then your running down the highway with the converter unlocked all the time which will cook the trans. So often I was just putting it down into third to keep the trans cool and just keeping it there, which defeats the purpose of having an overdrive trans to begin with.
When it comes to pushing a brick through the wind, gearing for "economy" will hurt you more than it helps. GM really f*cked up the gearing options of the 4x4's in the 80's and it was a very poor attempt to gain economy. You don't want to do what they did.
Auburn, Washington
^Good point. And agree. Underpowered OE engine and OD trans, has no business having gears that start with a 2 or even low 3s.
Also suggest OP run some rpm/gear calculator options to get a visual of what rpm’s will be in upper gears at certain speeds. For reference.
Zelph
Nevada
I’d go with 4.56. I like having the grunt to power up steep inclines and maintain a speed. A top speed of 70-75 is just fine by me.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
There are 383's and then there are 383's. Engine internals will dictate where your torque will be rpm wise, and also how much torque overall, anywhere from 300-500. 2.73, 33" tires, 2000 rpm's and .67 OD=about 107 mph. Just changing to 3:73 = 78 mph. 4:10=71 mph. 4:56 = 64mph. Bucket is on the money, 4:56 @ 2800 rpm = 90mph, which is more then acceptable for sb, or bb. Overdrive make all the difference. Friend has a performa built 700r4 behind a 427 sb 650 hp, and has blown it twice on six months. There is a guy in Calif that worked for GM transmission, in his 70's now. He sells a kit that last check was about $1100 hand written instructions. My friend Tom has built a bunch of these. He is in the process of building three more. His son has a procharged 498 I believe, close to 1000hp with one of these modded trans, and it has not broke. Just some info for ya. Make sure when you build the motor, take pics so we can enjoy following along.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Agreed. I'm off the basis of a worn out 350 and 33's and 35's. Highway is liveable, interstate would not be, not at 80 and 35's anyways. Lifted squares don't belong at 80mph anyways lol.
The first gear is really nice even with 35's on the street and casual off-roading. You'd want to be in low range for any real crawling anyways. That and his usage is why I said 4.10's. Mountains could use 4.56's though, was just dependent on his usage and engine build.
labratm
Nashville
Ryan
I have a similar setup, 86 383 4x4 with 33's with a 4l60e. I went with 4.11's and it's pretty much perfect. You could probably go a little higher numerically but I wouldn't go lower.
gmbellew
Kansas city
glen
suburban 1500
I have 350tbi/4L60/3.73 in my burb with "33's" that actually tape out around 32 inches. it is adequate enough that I won't likely regear but will look to add about 50 more hp when the engine dies. really it isn't bad on the highway cruising around 2100 RPM at 74-75mph flat ground. it does unlock the converter on mild hills and downshift on more significant hills, but it doesnt seem that much different than my 2004 burb, honestly. what really hurts drivability is any significant cross/head wind. that really kills it on the highway and I usually back off the speed a touch to help. I do about 15k miles a year in mine, with over half that spent on the highway between home and the farms (300mile one way).
if I was in a position with 2.73 gears and was going to regear for sure, I'd be a tough call between 4.10 and 4.56, with a slight nod toward 4.56 probably. that'd put me around 2400rpm cruising at 74-75.
I'd play with the rpm calculator with actual tire sizes and see what you think you want based on the engine's power band.
Rustisbest
Driving > posting
Athens, TN
Dont be scared of a little RPM. For brands I'd recommend Motive (not the cheaper sets) or US Gear if they make anything for your axle. The few I've done have been dead silent
Camar068
10 yrs Air Force
about 6 years ago I had mine regeared from 3.08 to 3.73 with Richmond gear Excel...only complaint I have is I didn't do 4.10. Very hilly interstate here in SE KY. I don't shift into OD until I'm doing 75 and if passing someone at 80 going uphill, I downshift to 3rd. 32" tire/4l60e/stock LS/stock height.
At 85 I don't worry about the hills as it want's to go well, It's really ready to go +90. Coil overs on front and rear so at that speed it rides like a dream.
henryfox
