83 C10 Grill
dylannewsome
Goldsboro, NC
Dylan
First post here on any forums, I tried to search through some threads to see if this has been posted about. If so please just direct me to the correct forum.
I've had several squares, but think I've found the one I'll will keep for awhile. I don't currently have two so I can't compare them in person.
83 C10, don't believe it's a Silverado package, I have the grille with dual headlights instead of quads. I'm curious as to what I can do to get the quad headlights on my truck.
Thanks for the help!
smullen
Fredericktown, Mo
Scott
I6
Taggin in to learn...
Seems like you could get a catalog from any one of the many vendors that sell practically every part there is on a C10.
Then look at the exploded diagrams, list and order all the parts you need from one of the ones that have the lights and grill you like.
I have an 82, that amount many other things I want to fix or replace. It has one of those Phantom grilles that half ass hides all the headlights. I want to rip it all off and buy all new factory stuff...
Maybe I can sell whatever I take off, to help pay for some of the parts...
Strick
Dunn, NC
Harold
C20 Crew
I have a radiator support from an '83-84 Custom Deluxe that was the quad headlamp setup. I'm not certain that there's a difference between the dual or quad though. Pull your headlamp trim and see if the provision is there for the lower high beam light. If so then you should be able to source the buckets and some aiming bolts/inserts and convert it to quad.
Strickland
Craig 85
Nashville, TN
454/TH-400/NP205
Here's the differences between the core supports.
Dual Headlights
Quad Headlights
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
not the same light pod from 2 to four ;)
kirktim
